Results 1 to 6 of 6
Thread: VWR Air filter
    Oct 2013
    Czech Republic
    VWR Air filter
    Hey guys,
    I am new to this forum. I have a GTI since July 2013 and have two questions )
    At first. I have 5000 km on it and 1/2 liter of oil used????
    Second. Already installed VWR cat-back exhaust and they gave VWR panel (cone) air filter as a present. Do I have to put it in??? Some are for it, some not???? Any ideas. They are saying...you will damage MAF, dust is going to the engine. But bloody hell, why those companies sell air filters whom can damage engine for 100 USD????? )))
    Thanx guys for reply.
    Jerry
    Polo GTI 2013, 3 door, Candy White, VWR Exhaust, VWR panel air filter, VWR license plate holders, VWR sport springs, VWR sway-bar, red GTI badge at rear, RCD 510, AC, comfort pack, MFS, MTM shifting paddles.
    Dec 2012
    Sutherland Shire, Sydney
    some engine consume oil, some don't, that rate is not concerning as long as your exhaust pipe is dry/sooty
    The K&N air filter is meant to provide superior air filtration so dust should not be an issue
    The problem is the K&N air filter needs to have oil applied to it
    If you apply too much the excess will get sucked in and can damage your MAF ($230~$250)
    I've been running a K&N for 18,000 and have not had a problem (Skoda Octavia 2L)
    Pretty sure the VWR panel filters (which are made by Pipercross BTW) are un-oiled.
    Jul 2011
    I thought the VWR filters did have oil but meh
    Also adding too much oil to the filters in these cars doesn't matter. VW cars (turbo, not NA) don't use MAF sensors of any kind (hot wire, cold wire or gate). They use MAP (manifold air pressure) sensors (one before the butterfly valve and one at the inlet manifold) they work by measuring the pressure along with a temperature probe to measure air density / volume.
    The reason they use this is because these engines natural have a lot of oil vapor coming out the PCV valve which would clog up a MAF in no time
    Oct 2013
    Czech Republic
    Hey guys,
    Thank you for replies!the filter is lightly oiled. 3 layers of foam. Like you mention, made by Pipercross or ITG. I will put it in!! Or I have a chance to switch it for KN???
    Oil usage, I will continue checking the level. My mechanic said to change oil every 10000 km.
    Sent from my iPhone using Tapatalk - now Free
    Oct 2013
    Czech Republic
    Already installed and its great, faster turbo spin and better sound of VWR exhaust! Instalation easy. Now the VWR sport springs are on the way to me!
