Have you installed led bulbs? They can do odd things as they age. They double speed is normal if a bulb error is detected. You could try to disable bulb error check in vagcom.
hi guys
weird error today
when i indicate, bulb error comes up, and the corresponding indicator light on the dash clicks at high speed, yet the outside indicators are flashing normal...
can anyone help
a copy of my latest autoscan as below
thanks
Monday,02,September,2013,16:53:40:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 6N0
Scan: 01 02 03 08 09 15 17 19 25 2E 44 55 56 77
VIN: WVWZZZ6RZDY215624
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CTHE) Labels: None
Part No SW: 03C 906 026 K HW: 03C 907 309 N
Component: 1.4l R4 TSI H02 4539
Revision: LNH02--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TSI01103C906026K 001005
ROD: EV_ECM14TSI01103C906026K.rod
VCID: 2855E67953E83A9
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3650
Revision: 00043014 Serial number: CU501302095652
Coding: 0000020
VCID: 2855E67998E83A9
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 23DD6885432402C5C41A166BC255408D0905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH.rod
VCID: 8F272DE55646CD1
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387536398B48AA9
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 042130827
Coding: 7DB02BAF68A10000093809916E2B0FD15AC0472F6035104020 0000030000
VCID: EBDF59750A9E511
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250113 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD
Component: J387__TSG_BT 008 1611
Coding: 18BC30
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Coding: 081001
Subsystem 5 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Coding: 830000
Subsystem 6 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 18BC32
Subsystem 7 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 18BC32
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag01D H10 0020
Revision: -------- Serial number: 003GZ001A33S
Coding: 003144
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4C9D7AE9E7D0369
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40691OC1G3PRV
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405L1PU925G9V
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB401450DEEDPJJ
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB401450DEEFGE8
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
Component: KOMBI H05 0607
Serial number: 00000000000000
Coding: 140E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 346D02099F204E9
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 002300
VCID: F0E54E1923B8B29
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EAD15C710D64489
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664222595
Coding: 010100
VCID: 2A511C7145E4089
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11241
Shop #: WSC 00788
VCID: 30650E19F738729
Address 55: Xenon Range (J431) Labels: None
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0116000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: F7F775054ED6E51
Address 56: Radio (J0503) Labels: None
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N1958981
Coding: 01000400020001
VCID: 244DF24927C0DE9
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158469
Coding: 0200000000000010
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_VW25.rod
VCID: 3B7F2935B27E811
End ---------------------------------------------------------------------
Harry
MY15 RED Polo GTI 6C - with DA Pack
08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
Yeah. Only for reverse light and its the indicators that r playing up indicators are normal bulb
Harry
There is a software update for this issue on 6R polo....go to your dealer to update the central electrics...fixes it every time...VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Cool
Thanks... Thought it was something easy that I can do with VCDS. Looks like I did the right thing by going to the dealer this evening,... However... As usual ... There is a week's wait before I can get in... I just have to put up with clickerty clack that's doing my head in... Wonder if I can get away with not indicating for a week![]()
Harry
