Results 1 to 5 of 5
Thread: bulb error and indicator clicking at high speed
    May 2013
    Hervey Bay, QLD
    Exclamation bulb error and indicator clicking at high speed
    hi guys
    weird error today
    when i indicate, bulb error comes up, and the corresponding indicator light on the dash clicks at high speed, yet the outside indicators are flashing normal...
    can anyone help
    a copy of my latest autoscan as below
    thanks
    Monday,02,September,2013,16:53:40:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 6N0
    Scan: 01 02 03 08 09 15 17 19 25 2E 44 55 56 77
    VIN: WVWZZZ6RZDY215624
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CTHE) Labels: None
    Part No SW: 03C 906 026 K HW: 03C 907 309 N
    Component: 1.4l R4 TSI H02 4539
    Revision: LNH02--- Serial number:
    Coding: 00250012002400000000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM14TSI01103C906026K 001005
    ROD: EV_ECM14TSI01103C906026K.rod
    VCID: 2855E67953E83A9
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: None
    Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 3650
    Revision: 00043014 Serial number: CU501302095652
    Coding: 0000020
    VCID: 2855E67998E83A9
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
    Component: ESP9.0i front H02 0002
    Serial number: --------------
    Coding: 23DD6885432402C5C41A166BC255408D0905
    Shop #: WSC 01383 785 00200
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    ROD: EV_Brake1ESP90iBOSCH.rod
    VCID: 8F272DE55646CD1
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
    Component: Climatronic H11 0711
    Revision: V0000000
    VCID: 387536398B48AA9
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 7H0 937 090 HW: 7H0 937 090
    Component: BCM PQ25 Max4 H72 0708
    Revision: B9072001 Serial number: 0531 042130827
    Coding: 7DB02BAF68A10000093809916E2B0FD15AC0472F6035104020 0000030000
    VCID: EBDF59750A9E511
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 250113 05 54 0403
    Coding: 06302D
    Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD
    Component: J387__TSG_BT 008 1611
    Coding: 18BC30
    Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
    Component: J245 PS72.023 H02 0007
    Coding: 081001
    Subsystem 5 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
    Component: E221__MFL-TAS H30 0032
    Coding: 830000
    Subsystem 6 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 18BC32
    Subsystem 7 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 18BC32
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
    Component: VW10Airbag01D H10 0020
    Revision: -------- Serial number: 003GZ001A33S
    Coding: 003144
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4C9D7AE9E7D0369
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB40691OC1G3PRV
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB405L1PU925G9V
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB401450DEEDPJJ
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB401450DEEFGE8
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
    Component: KOMBI H05 0607
    Serial number: 00000000000000
    Coding: 140E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    VCID: 346D02099F204E9
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
    Part No SW: 6N0 909 901 HW: 7H0 937 090
    Component: GW-K-CAN TP20 H72 0708
    Revision: B9072001
    Coding: 002300
    VCID: F0E54E1923B8B29
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0607
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
    VCID: EAD15C710D64489
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7664222595
    Coding: 010100
    VCID: 2A511C7145E4089
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 C
    Component: LenkhilfeTRW V278
    Coding: 11241
    Shop #: WSC 00788
    VCID: 30650E19F738729
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0116000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt_VW25.rod
    VCID: F7F775054ED6E51
    Address 56: Radio (J0503) Labels: None
    Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
    Component: Radio RCD510 005 0236
    Revision: 00000001 Serial number: VWZ1Z3N1958981
    Coding: 01000400020001
    VCID: 244DF24927C0DE9
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007664158469
    Coding: 0200000000000010
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_VW25.rod
    VCID: 3B7F2935B27E811
    End ---------------------------------------------------------------------
    Harry
    MY15 RED Polo GTI 6C - with DA Pack
    May 2013
    Orange NSW
    RE: bulb error and indicator clicking at high speed
    Have you installed led bulbs? They can do odd things as they age. They double speed is normal if a bulb error is detected. You could try to disable bulb error check in vagcom.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    May 2013
    Hervey Bay, QLD
    Yeah. Only for reverse light and its the indicators that r playing up indicators are normal bulb
    Harry
    Mar 2013
    Brisbane QLD
    There is a software update for this issue on 6R polo....go to your dealer to update the central electrics...fixes it every time...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    May 2013
    Hervey Bay, QLD
    Quote Originally Posted by vdubmotorworx View Post
    Cool
    Thanks... Thought it was something easy that I can do with VCDS. Looks like I did the right thing by going to the dealer this evening,... However... As usual ... There is a week's wait before I can get in... I just have to put up with clickerty clack that's doing my head in... Wonder if I can get away with not indicating for a week
    Harry
