Results 1 to 10 of 14
Thread: Brake rotor shudder
    Jun 2009
    Ringwood Victoria
    Brake rotor shudder
    Hi all
    Had an issue with my polo at service. The brakes shudder when braking from about 80kmph and the whole car shakes. Dealer agrees that there is a problem and is not caused by my driving but vag refuse to address it. Anyone else had this issue?
    09 VW Tiguan Black 125TSI Auto - RNS510, DynAudio, Mdi, Rear View Cam, BT, Sunroof, Cornsilk Leather, Comfort Pack, Side Steps, 18" NY Rims, Tow Bar, Mats, Tint
    12 VW Polo Pepper Grey 77TSi DSG - Sports Pack, RCD510 and Mdi iPod, Comfort Pack, Blutooth, Mats, Tint, Panoramic Sunroof
    Jun 2008
    Ringwood, Victoria
    Get that in writing from your dealer and then take it further. VAG generally will see brakes as a consumable and will not warrant them but if it falls within a reasonable time frame from new, you should have a case for a warranty claim. This should be done by the dealer regardless as they will still get reimbursed by VAG anyway.
    Where in ringwood you based azzamataz?
    Jan 2011
    i have had an issue as well with my steering shaking a lot when i break
    Aug 2011
    Perth, WA
    this would likely be to the brakes needing machining. This can happen to even new cars (say less than a month old).
    All it takes is hard braking, and then drive through a deep-ish puddle, and the brakes going from extreme heat, to cold can cause the steel to warp, leading to these conditions (steering wobble while breaking).
    I only know this because I found the hard way myself on another car.
    Adelaide hills, SA
    Quote Originally Posted by gavs View Post
    The brakes warranty is usually up to 20,000km.
    Jan 2009
    It's possible the wheel bolts might have been overtightened, and/or tightened unevenly.
    EDIT : If being the case, theory goes that whoever did up the bolts should be held liable for their actions.
    Jun 2009
    Ringwood Victoria
    Gavs i Live a stones throw from aquinas college.
    The dealer won't put itin writing, not that I blame them.
    Jexl I think u have the exact same issue as me. I'll let you know how i go with vag.
    Jan 2011
    it seems intermittent the issue is kinda gone now but was pretty bad a week ago...
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Azzamataz View Post
    Cool, I'll keep an eye out for you! I'm opposite daiseys, not so good on a saturday night.....
    Odd that if the dealer agrees there's an issue that they won't acknowledge it if they have been following it up with VAG. Maybe do a wheel rotation yourself, see if that changes anything. A wheel only needs to slightly be out of balance for it to cause headaches.
    May 2010
    Doreen, VIC
    My wife's Polo 77TSI Sportline had the same issue and the front discs were replaced under warranty. Apparently the measurements were 'out of round' and VWoA approved the replacement.
    Keep pestering your dealer I would say.
    Josh.
    MY07 R32. DBP. 6spd man. Sunroof. Rear parking sensors. Electric seats. RNS510. Bluetooth.
    MY10 Polo 77TSI. Flash Red. 6spd man. Sports package.
