Originally Posted by
wai
It's oil making its way into the inlet manifold/ports and points to worn valve stems, or the clearance between the stem and guide at its maximum serviceable limit. I don't know if the VW engines have valve stem seals, as it may be those that have failed.
The way to see if it is a major problem is to see if the exhaust pipe outlet is oily. If it isn't then it is a case of monitoring oil consumption. You will find that manufacturers will say that 1 litre/1000 km is acceptable.
The exhaust isn't oily thankfully. Just sooty after a couple of drives though. Mine falls at around ~300ml/1000km (car done approx. 13000km). The mechanics and service team at VW dealer reassured me that oil consumption is normal on the GTI, to just top it up when required, and that it wouldn't affect the rest of the engine. But I'm sceptical...
Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
