Could you not buy "aftermarket" options from the OEM manufacturer of your headlights? Not sure about your car but for Golf V you could buy the OEM Xenons with cornering lights etc from Hella for about $700USD.
Non-OEM aftermarket headlights are definitely out there, but you have to be careful and do your research - at the end of the day it's not the looks but the projectors in the lights that will be the most important for HIDs, and some headlights, though they have projectors, do not have the proper cut-off for HIDs.
If you don't mind opening your headlights and fiddling with them, the cheapest option with the best results would be to retrofit proper projectors in them - see this:
The Retrofit Source
If your country has restrictions regarding levelling motors / washers though, you might want to take that into account. The safest bet would be to find that OEM manufacturer.
