Results 1 to 10 of 16
Thread: Best place for new shock absorbers?
    Hey guys, so after specifically telling Berwick VW that the front suspension seemed dodgy and crashed over bumps and smashed onto the bump stops over speed humps, they 'road tested' the car and came back with 'nothing abnormal found'.
    After the car was serviced yesterday, at an independent, they said they checked the suspension and found nothing. Now, just today, we replaced two tyres and Tyrepower said that the front right shock is leaking oil badly and it needs replacing as soon as possible.
    So, firstly, let's jut say this is another classic example of VW Australia at it again – denying their customer's problems in the pursuit of, well I don't know what. Making customers feel like idiots?
    Anyhow, does anyone have any recommendations as to where we should look for replacements? We're likely to replace all four shocks due to road conditions and how many k's the car has done.
    I've got one quote from Pedders: $1458 for all four shocks incl. installation and alignment. Apparently the only shocks for the polo they have are Koni's which seems like overkill but I'm not sure.
    Thanks,
    Alex.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Jul 2011
    Could get OEM, shouldn't cost that much. I would say Instalation will be a high cost because of the work involved on the front. Just curious how many km have you done? And which one/s are leaking?
    If your somewhat capable at mechanical work you can install the back ones easily which will save some money...
    Quote Originally Posted by nomadx38 View Post
    Yeah I'll call VW during the week and see what they want to charge for them.
    The car has done 89,000 km and the leaking shock is the right-hand front.
    Alex Aescht
    Or you could buy my springs and shocks from my old GTI? They were pulled out with just on 1000k's on them. $400 + postage
    Jul 2011
    Quote Originally Posted by BLN355 View Post
    That's worth it! Umm the lowered springs could be a problem though. I know they aren't lowered that much (15mm) but still lower than the stock TDI springs. Clearance could be a problem as he uses the polo on rough terrain.
    Certainly a good price, but as stated, we live at the end of a dirt road that the council tends to forget about when it comes to maintaining, not to mention that there have always been clearance issues even with the stock setup, so it most likely won't be practical. Thanks for the offer though, not bad at all
    Alex Aescht
    Erskineville, NSW
    If you get the GTI kit just use the dampers with your OEM springs.
    The Koni Sports Adjustable (Yellows) are a great piece of kit. My mate has them on his 2012 Polo. They transform the vehicle. He bought them from Wholesale Suspension in Penrith & they were around $900.
    Koni also do FSDs but I'm not a fan.
    The rears took us 30 minutes to fit. The fronts around 1hr per side IIRC (maybe 1.5hrs tops - we'd never done a Polo before).
    I have Koni Sports on my Octavia - bought them from ECS & they were about $600-$700 delivered if your willing to take a risk on warranty.
    You can get Monroe or Boge off Ebay and there are a number of suppliers in the UK you can research / buy direct from (Micks Garage?).
    Your other alternative might be some coilovers. There's no law that says you have to immediately put them on their lowest setting.
    Thanks for that.
    I'll be doing some more research this coming week and we'll see how it goes.
    Alex Aescht
    Singapore
    Monroe Reflex Twin Disc technology has also released shocks for Polo 6R, they have it in standard which works with regular springs and Sports chassis for GTI model and those who want to lower the car with GTI or Eibach/etc springs. It feels softer on bumps but stiffen up the the car is turning or braking. Good pricing too.
    Erskineville, NSW
    That is similar operation to the koni FSD. I've had dampers like that before. IMO, they don't react quick enough. eg: they do an initial lurch then stiffen up when you want a linear response.
