So what's you beef with the tune, not what you expected, not enough power/torque?
There is the ability to erase fault codes. So for example you unplug something with the ignition on it will log and store a fault. One you plug it back in you can then clear the fault if this option is uploaded during the tune.
There is also a security code for the tune so you can lock It and no one else can change the program it's on. Wether it be the 98ron tune or stock
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
I don't have a beef (as yet) I just haven't noticed much of a difference drivability wise. Iv had a thew cars I have got tuned and you can tell the difference between stock and tuned straight up ( throttle response, pickup, no flat spots ect). This one I can't. I'm not going to make any calls untill I look into it more. Going to do some runs when I get my gear back from a mate. Maybe a quick dyno check. But I ran around the block in stock and then went to the tune and did the same block after it had cooled back down (amb temp was the same) and felt no difference. Might check boost with vcds but I'm not sure if boost is increased with the tune or not, where and what increase from stock.
True, but VW will disagree. If you are worried about a vehicle with issues with seals, rings and DSG, think about your warranty.
My Polo (older 1.8t) is a very reliable engine, many suitable spares out there and a generic gearbox. Your fancy TFSI and DSG are crazy expensive to repair if something goes sour.
Sorry for the gloomy attitude, but you need to make an informed decision. VW is known to put up walls as soon as they see the ECU has been touched.
6 hour trial is only for ECU's that aren't CAVE engine ID, which sadly is mine so no trial for me. But just thought I should let people know.
Mods: 18x7.5 Tenzo Tracer, EZ Lip, Piano black front/rear emblems, Metallic foot rest, Gloss black vinyl wrapped roof, Weitec Hicon GT coilovers, HP CAI
Just curious guys. What is the differences in boost pressures between stock, stage 1 & stage 2 tunes?
2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
Remember the same engine is in the 118TSI Golf. I've been running APR Stage 1 since December 2010 (not sure how long "long" is in your post)
