Originally Posted by
Hail22
*brain farts*
Can we dumb it down for those who have had long days and want a simple cut version to assist in purchasing.
Sorry Hail22 - I like discussing this stuff in depth 'cos I always learn something with a guy like gavs is involved.
gavs
with all dampers, they have to cater for extremes in the operating conditions so I am sure that the stock dampers will have the adequate bleed controls to cope with higher compression/rebound forces related to drastic surface changes. If they don't, then it's pretty pisspoor on vw's behalf because even ford do it on the territory and that is a heap of crap car at the best of times.
Bwahh-hah-hah!! I hate SUVs so don't get me started...
I think we are also discussing radically different time frame for the damper wear - you mentioned them wearing out overnight while I meant they could wear twice as quickly as normal (still a long time for folks who change their car every 3 years).
I can tell you from motorcycle racing that it is AMAZING the amount of wear in a damper when you look at the oil from a rebuild - the oil is heavily colored from all the aluminum particles suspended in it (forks are even worse but it's easy to drain and replace so you do it all the time).
PUZ213
I'm running kw's ATM. But the rears are on max. As with sway bar I reckon well worth getting if u like a bumpy ride and better turn in
Do you get much lift off oversteer with the back end set up like that?
Resident grumpy old fart
