Originally Posted by
gavs
the winding is a fixed rate until the last portion of travel where the spring helps to decelerate the piston in the damper/stiffen the ride on the compression stroke.
this is only going to decrease the life of the damper if the damper overheats and aerates itself.
And here we have the essence of why the dampers can still fail with progressive springs - if Joe Racer installs lowering springs on his car (sorry ladies for the exclusion), it is more than likely that he will spend some portion of his time tearing about the 'burbs and twisties where the cornering forces will compress the springs in their OE rate portion.
So far so good. But as well as the cornering force loading, the springs also have to absorb mid corner bumps which are far from uncommon and this will often force the spring into the higher rate region where it is necessarily MUCH higher than for a linear spring (since we want the fully compressed rate to be identical to the full height OE spring).
In the compression phase, the damper actually has an easier time since the spring is deccelerating the unsprung assembly in conjunction with the compression valving. But the compression damping factor is far less than the rebound damping factor so the damper isn't working very hard in this phase anyway. In fact most cars used to have no compression damping.
When the spring rebounds, that higher rate section will expand first, trying to accelerate the unsprung assembly in droop and the rebound valving of the damper becomes overtaxed until the higher rate section is fully expanded and the OE spring rate takes over for the rest of the droop travel and the rebound valving of the damper operates at its designed flow. How long and often the damper operates in the overloaded state depends on how hard the driver is leaning on the suspension and how bumpy the corners are but it is in this range of motion that the flow rate in the rebound valving can become excessive, leading to cavitation which then aerates the oil and fades the damper leading to the overheating. The excessive flow also wears the valve assembly.
With higher rate linear springs, the dampers are always overloaded in rebound but at a much lower level so the dampers will wear but in a more predicatble manner.
Hail22
So in conclusion...Spring or Coilovers...I am sort of having a "cold war" moment here...whether to attack one option...or the other
I still maintain that changing springs alone is a compromise that it not worth doing. Either change springs along with matched (or adjustable) dampers or go to a quality coilover - some coilovers have dampers that are no better or are actually worse than OE (which is why than can be so cheap vs springs + dampers as who would buy a crappy damper on its own?).
Reason: emphasis add for clarity
Resident grumpy old fart
