Results 1 to 5 of 5
Thread: Anyone towing here with a DSG gearbox?
    Nov 2010
    Perth
    I'm looking at getting a quad & trailer but need to add a tow bar first. I see that VW rate the Polo with tow capacity of 1000kg brake assisted and 530kg non-assisted.
    Anyone here using their DSG Polo to tow a trailer? Notice any issues? And should I get the VW tow bar?
    POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
    Engine - K&N Air Filter (e-2997)
    AV - Rockford Fosgate T1652-S , T1652 and P3L-S12 Sub. Alpine MRP-F600 and Alpine MRP-M500, Dynamat
    Planned - lots, but the "financial manager" says NO
    Feb 2008
    Townsville QLD
    To fit a towbar you WILL need to go genuine, the issue will be the electrical harness, and no-one does this after market. Expect to pay a small fortune.
    The towing capacity that VW do not advertise but the one that WILL limit what you can tow is the towball download limit.
    My experience is with my passat, cost $1500 upwards depending on dealer, 2000 Kg towing capacity but a ball download limit of only 85 Kg. In Australia anything you tow usually has a ball download of 10% of gross weight. In my case a 2000 Kg limit is nonsense as the ball download restricts me to 850 Kg or, in reality, a box trailer.
    On a pro rata basis if a polo ball download limit is (say) 45 Kg then your quad plus trailer will need to be around 450 Kg so check all your numbers carefully.
    For those that may say that the ball download limits are unreasonable, the limit is determined by the ability of the rear suspension to absorb that load, not the towbar. I have seen what 200Kg of pool salt in the back of the Passat boot does to the rear end, one up. I would hate to think of the drag ar$e with 4 adults aboard plus holiday luggage in boot plus 85 Kg download on the towball.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    You could give Hayman Reese a call.
    Nov 2010
    Perth
    Thanks for the info vanDub
    Feb 2008
    Townsville QLD
    Quote Originally Posted by broxigar1983 View Post
    My pleasure as thats what this site should be for, not the pi$$ing contest that most threads deteriorate into.
