Results 1 to 5 of 5
Thread: Anyone running a decatted Polo?
    Thinking of Decatting mine for when i go stage 1 to get some nice pops and bangs. however if i were to leave the stock cat would it ruin it?
    Sep 2015
    Canberra
    Well, it's illegal.... so I assume you're talking about doing it yourself, because your tuner / mechanic shouldn't be doing it for you.
    Stage 1 is designed to work with the OE DP / cat. Stage 2 on these is just a tweak to that file for people who run a bigger DP so it doesn't start throwing codes from confused air sensors. As in, Stage 1 + Test Pipes File = Stage 2.
    The DP is adding any extra HP, the tune effectively doesn't change.
    If you run decatted with stage 1, your engine could start throwing codes because the lack of restriction is unexpected.
    Invest in a good DP with a sports cat, or just enjoy stage 1 as it is. Or come at it from the front and upgrade your intake; you'll hear more induction sound from doing that.
    2014 Audi A1 Sportback Sport
    APR Stage 2 - HP DQ200 DSG tune - Quaife DQ200 LSD - LuK RepSet 2CT clutch - VWR CAI - Wagner Competition FMIC - Milltek DP & resonated cat-back - HP F&R sways - Bilstein B14 coilovers - Tarox Sport Compact brake kit - GFB DV+ - Whiteline LCA bushings w/ +caster - SuperPro race dog bone insert - Fondmetal 9RR matt black 18x8" wheels - Michelin PSS 245/35R18 - gloss black RS honeycomb grille - OEM clear lensed LED tail lights
    Jul 2007
    Brissy
    You may need a special tune as the ecu will expect the post cat sensor(s) to give a certain value which won't happen, so it may lean it out or just throw a CEL.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2011
    Stage 1 runs on the stock DP fine. As said above stage 2 only really clears the CEL that's thrown from it.
    There at are a few other changes that are made but not much. Boost can be increased if there was a previous restriction and timing etc can be adjusted to better suit the peak boost that comes on sooner.
    Also there is the lean running issue that could effect you but if the 1.4 (or 1. is anything like the 1.2 I have it automatically trims the fuel injection anyway.
    The pops, bangs and flames you get from catless though are a reason to do it in itself, especially starts on cold mornings haha
    Jun 2011
    Larrakeyah NT
    WTF, Why would you want pops and bangs! Makes you car sound faulty, and attracts cops.
