Originally Posted by
lunchboxGTI
The koni sports are designed for the H&R springs. Which I already have. If you buy a kit you get H&R with them.
I had the springs first which naturally made it stiffer but it just didnt take the sharp bumps well at all. then I brought the sports thinking they would be well matched but they where stiffer then the weitec coilovers (with the lowered springs) a friend has and I felt like I was back in my old track wrx. So I got the FSD as they ar ment to match the H&R as well. There not as comfy as stock but they work well when pushed and don't bust your kidneys on the big bumps.
If you get shocks with a good spread in the rebound adjustment you can counteract the sharp action of a stiffer spring forcing down and smooth it out but the koni sports just don't have the spread. There not focused enough for track and to harsh for the road.
There must be something not quite right.
I've fitted Koni Sports (Yellows) to a 6R Polo & the damping is very benign. Initial bump over concrete strips is very forgiving, esp compared to Bilstein, which have stiction problems & very firm initial damping.
