Originally Posted by
kawabanga
I installed 10mm on both axles.
I found a worse response on the steering wheels: the car is less responsive, seems that you need to turn more the steering to have a pair response on the road...
Yep - poking out the front wheels more increases the scrub radius which borks up your steering response. Plus they're illegal in most states in Australia.
Resident grumpy old fart
