Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 148
Thread: Anyone got a Sway-Bar installed? Care to voice opinions???
    Apr 2012
    Hey,
    Looking at getting A Whiteline Rear Sway-Bar for my Polo GTi. Wanting to know if anyone has had this installed and noticed a significant difference? Anyone from the the Sydney area willing to demo?
    Whiteline
    Launceston, Tasmania
    Quote Originally Posted by Bassik View Post
    Hey,
    Whiteline
    Yeah mate, had one on for about 6 months. (I beg forgiveness at the feet of kaanage for my poor technical knowledge) Doesn't stop body roll -set on medium- but it does stop the body roll from pulling the car around further. Put more clearly, it makes the ride more stable and controllable. It's worth buying, you will notice a difference.
    Unfortunately I'm in Launceston. So probably not much help for a test-drive.
    Apr 2012
    Thanks mate,
    What was the reason for getting it removed? Are they to noisy or something?
    Apr 2011
    Sunshine Coast, QLD
    I understand this will help the drive when driving enthusiastically. How about daily driving? I find the suspension already quite stiff. If I were to get one of these, will my behind and back suffer further during the commute?
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
    Apr 2012
    Quote Originally Posted by RoknRob View Post
    I can only compare by two totally different cars. I find the Polos handling rather bad compared to my DC2. If you think the suspension is already stiff, I'd say don't modify just deal with it and it will be fine. Although not having installed a sway bar my DC2 is really stiff. I have coil covers but even on the softest setting it's painful in traffic and bumpy roads
    Jun 2008
    Ringwood, Victoria
    In day to day driving, a rear anti-rollbar or stiffer front anti-roll bar won’t make any discernable difference to how stiff the car is. An anti-roll bar is a spring that connects the 2 springs on the same axle together so that when the vehicle experiences the weight transfer that causes body roll, the car doesn’t lean or roll as much. The anti-roll bar works generally only when one spring is loaded and in compression and the other is extending and unloading. It works to increase the torsional stiffness between the 2 springs so that it takes much more force to twist the anti-roll bar to generate that same amount of body roll. This is how the whole rear axle of the polo works with the torsion beam axle.
    So, if the outside spring was allowed to previously compress by 15mm in a corner, with the other spring on the axle allowed to comparatively extend which induced the body roll, with the anti-roll bar in place, the bar is not put under enough load to twist far enough to induce the same amount of roll, so you only get 1mm of outside spring compression, limiting your body roll. I won’t get into the handle moments of how adjustable bars work.
    Can the normal daily commuter do without a rear anti-roll bar? yes, for sure. For 90% of Polo GTI owners out there, the car does exactly what they want it do do in cornering prowess. For those of us however that like things a bit flatter, then you would consider one.
    Apr 2012
    Quote Originally Posted by gavs View Post
    This is why I am getting one. Hey gavs is there much work installing a front bar as well?
    Jun 2008
    Ringwood, Victoria
    Ooooh yeah. You have to drop the whole front subframe to get it in there.
    Apr 2012
    Hmmm.. ok maybe give the rear a go first. Hopefully get it installed by the weekend.
    Apr 2011
    Sunshine Coast, QLD
    In summary, no difference in day-to-day driving. Noticeable difference when pushed.
    That's what I thought. Thanks. Might give one a go at some point, then....
