Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 148
Thread: Anyone got a Sway-Bar installed? Care to voice opinions???
  1. #101
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by 06eleven View Post
    That was the story back in the day, might not have been right though. Does your GF have a 180? Has it fallen to pieces yet?
    No she didn't end up getting one, she ended up going and buying new instead by getting a 207 and that's just as bad. It is after all the same body underneath the exterior sheet metal but still, the rear window shaking while driving over the cobble stone patches around her area is pretty rubbish. She is goin to sell it and look at a hyundai, I'm steerin her toward the voloster.
    Bassik a front anti roll bar that is thicker will give flatter cornering but will start reintroducing under steer into the handling characteristics.
  2. #102
    The main reason to get a front bar in place is to help stop the weight transfer that reduces your corner speed.
    On the Polo (and the majority of FWD cars), a huge percentage of the weight is in front of the front axle (have a look next time you have a front wheel off, your wheel centre line & the centre line of the engine / transmission).
    When you hook into a corner, the weight transfers to the outside front wheel, and unloads the inside rear wheel (There are many pictures of Polo's & Golf's carrying the inside rear wheel). If you ever get to look at shock data & weight loads from a FWD car, reducing that transfer makes a faster car - Ideally if you could keep the load very neutral front to rear in cornering, that would be perfect (like a mid engined Cayman).
    Making the rear end "stiff" or "loose" doesn't do anything for corner speed, it might feel like you can tip it in better (feel less understeer) - let the FWD pull you through the corner as FWD's do best.
    Watch some of the footage of the BTCC, I have seen the suspension setup in those things, and the bias is certainly not towards a stiff rear end
    my 2c anyway.
  3. #103
    Apr 2012
    So if I go ahead and get a front sway bar and reduce the stiffness on the rear that should in turn reduce the over steering... theoretically?
    I felt that the rear did wonders but now given I'm used to it I feel I need more stability in corning. I know at the end of the day I just need to get used to driving my new car over the DC2.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  4. #104
    It certainly will shift the oversteer - you just need to spend a lot of time on all your settings, including wheel alignment & tyre pressures - unfortunately suspension tuning is not a one dimensional thing!
  5. #105
    Jun 2008
    Ringwood, Victoria
    Very very true. Bassik, if you crave flatter cornering then the easiest way to do that is by putting stiffer anti roll bars in the car. If you still want it to be flatter again as well as being able to tune the handling, you will need to look at compression and rebound adjustable dampers with various spring combos, coupled with camber adjustment strut mounts, castor kits, bracing etc.
  6. #106
    Apr 2012
    Sound all very expensive to me. I didn't want to go down the coil over path. I would however get a front sway bar or any other minor advancements to improve handling. I didn't want to substitute comfort over handling but looks like I have too, I wanted somewhere in the middle... I guess I'm at that point now???
  7. #107
    Apr 2012
    Just got an email back from Whiteline after asking if they were going to be development a front anti sway bar. The response was
    "Sorry only the rear bar we list as we feel that is all that is needed. If you add a front bar it will bring back the understeer it had from factory"
    So looks like rear is the best option... and front will in fact coz more understeer!
  8. #108
    Aug 2006
    Far North Qld
    just got mine installed yesterday, very happy with the result.
    Is there any point in keeping the old one, as the mechanics didn't put it in the car.
    cheers
    White 3-dr Polo GTI
    Tiguan 189TSI
  9. #109
    Apr 2012
    Quote Originally Posted by Tigga1 View Post
    cheers
    What did you get installed? The old one...There was never one installed, isn't that why you got one?
  10. #110
    Aug 2006
    Far North Qld
    Quote Originally Posted by Bassik View Post
    ah...well you got me there.
    I wasn't sure whether there was one previously, as I never looked, but my invoice says "remove old sway bar and replace with new one supplied"...
    anyway, it is a H/D 24mm adjustable whiteline
    White 3-dr Polo GTI
    Tiguan 189TSI
