Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 148
Thread: Anyone got a Sway-Bar installed? Care to voice opinions???
  1. #91
    Mar 2011
    Brisbane, Queensland
    Talk of dangerous lift off oversteer came up in the old Polo section. From memory a number of us chimed in saying we had not experienced it and didn't see the concern
    This is not to say it can't happen, just seems to be a possibility, not an every day reality. As the design of the Mk4 and Mk3 is similar, you could look on other forums for experience in this area. I ended up going front and back, but the rear on its own was a good improvement with the stock suspension, you already have a front bar, just soft.
    I have had the liftoff happen, but mind you it was mostly due to lapse in concentration and a little bit of carelessness aswell (forgot im not driving on coils). Threw the polo into a turn on a track during a course and felt a really really bizzare pivoting feeling from the front. Didnt know what had happened at first, but one of the instructors was watching and told me that the rear left was in the air... Swapped back to the middle setting since...
    Will deffinately save my pennies to get both the front and back from HP here in Brisbane though. Still not a big fan of not having the silly u-bolts over the rear beam on the whiteline.
    2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
    Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
  2. #92
    Oct 2010
    Melbourne, VIC
    Depends a bit on the relative spring/damping rates front/rear and how hard you drive.
    My 9N3 can generate liftoff oversteer quite readily when driving on track (have spun it a couple of times) even without a rear anti-roll bar. On the road, I don't push hard enough to get lift-off oversteer - just tightens up of the nose but I believe it could oversteer if I was forced to brake in a turn.
    I suspect that the B12 kit that I have fitted has stiffened up the rear relative to the front as the stock suspension allowed me to brake quite hard while turning in to downhill corners without oversteer.
    Resident grumpy old fart
  3. #93
    Apr 2012
    Quote Originally Posted by Trepid4tion View Post
    HP you got link, I can't seem to find any other front sway bar other then the APR one for the 6R?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  4. #94
    Mar 2011
    Quote Originally Posted by Bassik View Post
    Sorry, yeah it is the APR one, but going through Harding Performance here in brisbane to get them.
  5. #95
    Apr 2012
    Wondering if it would be ok to have APR front and Whiteline for rear?
  6. #96
    Quote Originally Posted by gavs View Post
    Honestly, I find this a little hard to believe. the amount of booming that comes from the rear end especially on uneven roads due to the the whole body shaking is really disconcerting, to the point that it has annoyed my girlfriend so much, I either have to fabricate an brace for her car or she sells it.
    That was the story back in the day, might not have been right though. Does your GF have a 180? Has it fallen to pieces yet?
  7. #97
    Oct 2010
    Melbourne, VIC
    It'd at least as good as the Whiteline rear anti-roll bar with the OE VW one up front (better IMO)
  8. #98
    Apr 2012
    Quote Originally Posted by kaanage View Post
    What does OE mean?
  9. #99
    What does OE mean?
    Original Equipment
  10. #100
    Apr 2012
    So your saying don't get a front sway bar?
