Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 148
Thread: Anyone got a Sway-Bar installed? Care to voice opinions???
  1. #61
    We do sell them separately, but we strongly recommend you run a pair on your car.
  2. #62
    Jun 2008
    Ringwood, Victoria
    If they keep tightening without actually getting tighter, fair chance you have stripped the nuts (they use grade 12.4 bolts) or you just didn't have them tight enough previously maybe.
    Other options include Volkswagen Racing, Eibach, Neuspeed, KW, H&R maybe too. Aside from APR, Whiteline was the only company that made a rear anti roll bar.
  3. #63
    Apr 2012
    Quote Originally Posted by gavs View Post
    I will have another look and re-tighten, by the looks from other pics the amount of thread visible is comparable with mine yet I can keep tightening. I will take a picture tonight and post to see if you notice anything that maybe wrong looking. I noticed in another thread gavs that you had posted pictures of your anti roll bar, you have another plate under your axle beam then the anti roll bar screwed around that?
    Are these other options for front anti sway bar?
    Thanks Guy_H but as I mentioned there is no point in me getting the rear as I already have plus the whiteline can be adjustable the APR cannot. What's the price for just the front if you don't mind me asking?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  4. #64
    Jun 2008
    Ringwood, Victoria
    Yep, for the front. I'll take a look for you if you post the pics but I think I might already know what the issue is, before I say anything though, I need the pics.
  5. #65
    $425 each including GST - oh, our bars are multi point adjustable on the rear too
  6. #66
    Oct 2010
    Melbourne, VIC
    The APR Aus site says $425 each so I assume that applies to buying either the front or rear anti-roll bar.
    edit - Guy's beat me to it
    If you can keep tightening the nuts, then remove one have have a GOOD look at the threads both on the bolt and in the nut - one has yielded (hopefully the nut which is easier to replace). Did you use a torque wrench for the install?
    When replacing the fasteners, I'd highly recommend you use Loctite ThreadLocker 242 or even StudLock 262 which will also lubricate the threads while assembling (giving more accurate installed tension).
    Resident grumpy old fart
  7. #67
    Apr 2012
    Ahh ok I thought the price was $425 each meaning they came as a set (rear and front) So the rear and front are advertised at the same price, therefor as a set they are $850?
    Ok I'll post up tonight. Funny coz I got my mum's BF (Mechanic) to install it so if I you find any issues I'll know he ain't the best person to ask again for advise...Mind you he is a stressed mechanic and for the past 10 yrs has wanted to get out of the business...lol Oh and advised me to "NEVER BUY A VOLKSWAGEN" I so didn't listen!!!!
  8. #68
    Jun 2008
    Ringwood, Victoria
    No worries mate, i'll check later tonight.
  9. #69
    Melbourne, Victoria
    Wow $425, that is steep.
    2011 Polo GTi
  10. #70
    Of it was the price for the pair then it would be a good and fair price.
