Absolutely correct. People complain about cars having an understeering response but the truth is that most people cannot handle liftoff oversteer and the stiffer the rear roll stiffness is vs the front, the more savage will be the oversteer.
Particularly bad (and not hard to get into) is the case where you enter a downhill turn that is sharper than you anticipated - it is instinctive to at least lift off the throttle in this situation and a car that is not heavily biased towards understeer (in normal circumstances) can easily spin. Even ESP would not necessarily save you in this situation if the corner is tight enough or you enter hot enough.
That said, Whiteline was referring to people who wish to track their cars and you would hope that these people would have some idea of what their vehicle response would be and, even better, would adjust their car back to more understeer when putting it back into road use mode.
Resident grumpy old fart
