Turns out the one I got delivered was a Whiteline and ways...
Should install on Sat....!
They have a VERY poor reputation for adjustable strut tops - never heard anything about their other products.
http://www.k-mac.com/pages/aboutus/about.htm
But yeah, an anti-roll bar is about as simple as things get.
Resident grumpy old fart
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
Sweet I am interested!
I'm thinking of getting a roll bar but I still have a question. I have AP coilovers on lowest setting on rear, and it is quite a stiff ride because of the light weight at the rear.
The roads I travel to work everyday are at some places extremely uneven (lots of left-side only or right-side only bumps), so if I was to install the rollbar, is the ride still doable or is it going to be comparable to no suspension at all? Because the left and right side will be linked together.. I am willing to give up some more comfort if there's an advantage in installing the rollbar though
Anyone with opinions on this?
I might be completely wrong but i don't think it impacts comfort when your travelling on a straight piece of road. Its all a matter of personal opinion on what you consider comfort. I'd suggest you get it and install it and see how you feel, if you don't like it, just resell it.
I believe the reason Hooti was selling his was because he had his car lowered and it was to much. I can give you reports after I install on weekend and Ill give you a reasonably critical response.
Yeah, ap's on mine were too firm with the other mods.
When the car goes over a speed bump, both wheels move symmetrically, it does nothing.
When you turn, the bar is twisted, reducing lean. When one wheel goes up or down over bad surface, the bar tries to straighten the car, not what you want for comfort.
No easy answer. It affects both cornering performance and comfort.
