Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 148
Thread: Anyone got a Sway-Bar installed? Care to voice opinions???
  1. #131
    Dec 2012
    Melbourne, VIC
    What are you hoping to achieve?
    On front wheel drive cars it generally makes more sense putting a stiffer sway bar at the rear, but it all depends what you are trying to achieve
  2. #132
    Apr 2012
    Trying to eliminate the body roll on cornering. I tend to take corners harder then usual and when I do I feel like I'm on a boat.
    BTW I have a rear sway bar and that helps but I'm used to it now so it feels like its stock again!
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  3. #133
    Dec 2012
    Melbourne, VIC
    Just be aware that the car will tend to understeer more which will reduce your cornering speed.
    It's all a balancing game.
    If the car does not understeer at all, then it won't hurt putting on a bigger front sway bar, but you don't want to over do it.
    EDIT: APR Tuning seem to have done quite a bit of work in this area. Have a look at what they recommend
  4. #134
    Dec 2012
    Melbourne, VIC
    Apr 2012
    Yeah the down fall is that I have a Whiteline rear sway bar already. How can this compare to APR?
  6. #136
    Dec 2012
    Melbourne, VIC
    Give them a call and let them know what you have done so far, they should be able to provide some useful advice.
  7. #137
    Jun 2008
    Ringwood, Victoria
    You need to find out the exact spring rates to find out any differences, something I am sure that most companies will not divulge.
    Look at an uprated fornt bar by all means but believe me, it is a right b*tch to install without a hoist.
  8. #138
    Apr 2012
    Quote Originally Posted by gavs View Post
    This from K-Mac, a hoist wont be an issue as my mate has he's own workshop.
  9. #139
    Apr 2012
    So I took my car to K-Mac and there was there guy there that helped me out with some advice in getting better handling done. He quoted me upgrade the front anti roll bar to a 22mm (stock is 20mm) apparently every millimeter adds 80% more stiffness around corning. He also quoted me to get a camber kit for both front and rear. $1100 all up or just $500 for front bar
    He reckons coilovers and spring as a waste of money...hehe
    What's you guys thoughts.
  10. #140
    Oct 2012
    Where is everyone buying the whiteline rear sway bar from and are they hard to install?
