Hi Guys,
I have put an amplifier (Audison SRx2) in my Polo over the last couple of weekends.
I was able to fit down the passenger kick panel area:
2x 8 Gauge (Power and Ground)
2x 12 Gauge (Speaker cable)
1x 18 Gauge (12+ Trigger)
1x Stereo RCA
Here are some pics of the amp under the back seat. I screwed little plastic feet to each corner, it keeps it in place perfectly on the carpet and I don't have to drill any holes.
This is with the seat back, perfectly hidden!
Here is the battery compartment I ran two grounds direct from battery, one straight to the amp and one straight to the head unit. The original position I tried on the seat rail wasn't too good. I know the ground is meant to be short, but everything is dead silent and I get no interference at all with the way it is currently wired:
This channel is right near the battery, there is a little rubber grommet in place at the end of it, remove it and you have direct access into the car!
The fuse mounted
Here is where I mounted the crossovers, under the glove box. It doesn't get in the way of your feet at all provided you cable tie everything in place
That's about it! Let me know if you have any questions about how to do it.
