Originally Posted by
wai
Look at it this way. The braking system relies on friction and wear. It is preferable to have the pads wear rather than the discs
Except VWs seem to wear the rotors at the same rate as the pads
To the OP: Unfortunately, heavy brake dust is common on VWs & many other European cars. You can fit low dust pads (talk to GSL rallysport on these forums).
In the meantime, try claying your wheels (inside & out) and using a good wheel wax or sealant. Weekly washes with a PH Nuetral wash will help as well.
