Hi guys, can I pair my phone to the RCD510 directly and leave the touch adaptor in?so I just use the Bluetooth function from the RCD510 and ignore the touch adaptor?
Anyone with a Samsung Note 1/2/3 found a mount for their phone? I will be upgrading from my iphone 4s to a Note 3, turns out it wont fit into the Bury XL universal mount.
Sure can.
On your phone, make sure you have unpaired the Touch Adaptor. Pair using either your phone's Bluetooth search or MFD (Bluetooth -> Users -> "search" or something like that) to the 9w7/unit under the seat (aka VW PHONE) which is linked to the RCD510.
From there everytime that you have your phone's bluetooth on before you start the car, it should automatically connect to your 9w7.
If it doesn't connect automatically, you can manually connect using the MFD by:
Using the left/right buttons on the steering wheel switch to the Bluetooth menu
-> Scroll to "bluetooth"
-> then "Users"
-> then choose phone.
Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
Pretty sure this is covered at the start of this thread...
I have just read the whole thread and am a little confused about a problem I'm having. I have a my13 polo gti and originally paired to the touch adaptor but then found I couldn't use Bluetooth audio streaming so changed to vw phone which works great. Problem is now my touch adaptor doesn't seem to have a purpose. Is it possible to use both in conjunction with each other if I wanted and still have bt audio?
I also have an issue where I have unplugged the touch adaptor to check it out and now I can't seem to reconnect with it. It says error connect to uhv or something. Any ideas?
Thanks for helping a newbie!
just a quick question as i am bit confuse. can i get a bury 9 xl cradle and repalce the touch adaptor without recoding? i am using the rcd510 directly and just want to use the cradle for holding my phone. so i just want to do as little as possible.
thanks
2013 POLO GTI Black
2005 MKV 2.0 FSI Black
My wife just bought a new Polo with the RDC310 and bluetooth touch adaptor (which is next to useless), I've found this iPhone 5 cradle on ebay, if I buy this for her will it be plug and play or is coding necessary?
Bury S9 System 9 Active Cradle CAR KIT FOR Iphone 5 | eBay
Thanks in advance lads.
Alan.
Did the same thing on my wife's new Polo two weeks ago.
Once we stopped the car and turned the car off and back on it worked again.
I'm looking at this for her (iPhone5)
