Results 1 to 10 of 16
Thread: Air Filters
    Apr 2013
    Air Filters
    Can anyone recommend? Brand name and Part No? Cost and where did you purchase it?
    BMC quote a cylindrical one -
    Code: FB576/08 Cylindrical
    CAR FILTERS FB576/08 | BMC AIR FILTERS
    while K&N quote a flat type -
    33-3004 - K&N Replacement Filters, Replacement Air Filter direct from K&N
    Which is correct? I have not opened the air box yet because I need to purchase a Torx scewdriver size T15? or T20?
    Not willing to go the full cold air intake yet.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
    Jul 2012
    Not sure about TSI & TDI's but GTI's (im thinking itd be the same....?) have cylindrical filters.
    This is the correct K&N one if you wanna replace stock filter. The BMC one is correct
    Arrawarra
    VW Racings seem to suggest the cylindrical one as well (VWRP J004), even though they still call it a panel filter ?? Seems odd!
    Yeah i ordered my k&n part number e2997.. Its a cylindrical one.. From ebay. $98 delivered
    Apr 2013
    Thank you all for your info. Has anyone heard of ecu errors registering after a change to these higher flow filters? and would anyone like to hazard a guess as to the size of the Torx screws on the air box. The VW tool kit one is a T25 and 30 which is too big.
    Aug 2013
    Air Filters
    Viezu is having a sale on panel filters and pod filters for all be models.$69 apparently add them on Facebook as it only a limited time offer
    Mar 2011
    Netherlands
    Quote Originally Posted by car_nut View Post
    Thank you all for your info. Has anyone heard of ecu errors registering after a change to these higher flow filters?.
    There will be no error as there will be no more air going in to the engine compared to stock filter. There will be zero increase in performance, only slightly better induction noise and you get the 'bonus' of being able to clean and reuse it
    Cold air intakes can increase performance, but cone replacements are only good for slightly better dsg blurts
    Arrawarra
    You can get handy little torx bit sets that have 6 or so bits of different sizes for fairly cheap. <$20 & you will probably use some of the other sized bits at some stage on other components...
    Jul 2011
    Haha lets not start a war (like what has happened in many other threads) but chaging to a high flow air fillter will give more volume and thus power BUT the power gains are pretty much not existent. At best it's 1kw/5nm, throttle response will be slightly better as well. The fact is the less restricting the filter is the less vacuum you have on the intake - and less vacuum is less turbo lag amongst other things
    Don't think that just changing the filter will show big gains because it won't, that's what a CAI is for - sort of
    Air Filters
    Will it burn less fuel ?
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
