Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Air Filters
    Jun 2009
    Quote Originally Posted by MJKooLio View Post
    Will it burn less fuel ?
    No, it won't.
    Jun 2008
    Ringwood, Victoria
    Air Filters
    Quote Originally Posted by nomadx38 View Post
    Haha lets not start a war (like what has happened in many other threads) but chaging to a high flow air fillter will give more volume and thus power BUT the power gains are pretty much not existent. At best it's 1kw/5nm, throttle response will be slightly better as well. The fact is the less restricting the filter is the less vacuum you have on the intake - and less vacuum is less turbo lag amongst other things
    Don't think that just changing the filter will show big gains because it won't, that's what a CAI is for - sort of
    At the crank you might see that if you are lucky, running at sea level on a cold, humid day the biggest gains you get from most aftermarket filters are induction noise and more crap getting sucked through due to the more open construction method.
    Just some info for you all, when I was part of the Soarer scene, one of the guys did a full-on test of a whole lot of different filters from panels, pods and cones, paper, foam and oiled etc and long story short, the supposed "best" aftermarket filters not only let through the most dust, but actually flowed WORSE than the factory paper filters.
    For induction noise and or convenience of long life, go the filter. For performance, intake and tune.
    Sep 2012
    NSW
    Quote Originally Posted by gavs View Post
    Any aftermarket CAI use factory filter? best of both worlds!
    ^^^^ correct. K&N filters etc are a waste of money.
    Jun 2008
    Ringwood, Victoria
    Air Filters
    Quote Originally Posted by Zakarados View Post
    Nope, but that's one of the trade offs you take with the extra breathing capacity of the cai's.
    I bought myself a k&n.. But the one that fits into the stock airbox.. Im going for a tune later on down the track. Wonder if ill see any gain from that.
