Page 15 of 20 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 194
Thread: Agressive wheel fitment
  1. #141
    May 2013
    is anyone running 18x8.5 et35 all round? If so how are you finding it? Thoughts?
  2. #142
    May 2012
    Quote Originally Posted by gavs View Post
    Exactly. I know some people like the easy option but while I do love the low'n'slow look on 'dubs, I can't stand it when it's not done right a wheel recentering kit is only a couple of hundred bucks and it fixes that issue.
    For a prime example of a brilliant lowered polo, have a look at Ryan's (Bflat) 9n. I see it probably once a week or so and every time I think 'man, that looks magnificent'.
    Have you seen a kit for the 6r yet Gavs. Had a search and come up empty handed
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  3. #143
    Jun 2008
    Ringwood, Victoria
    Should be the same as the mk4 golf....
  4. #144
    Aug 2012
    Albury, NSW, Australia
    is the mk4 axle bolted or welded to the (chassis rails)? and if it is indeed the bit im thinking of, on the polo its welded... keeping in mind i could be completely wrong and not know what im on about...
    [when i get my polo back i'll take photos to try help explain]
    @mrdeathlad
    #rollinonskittles
    Shorty exhaust, black tails, Kw V1
    Ronal, Oz, Hoshino Racing
  5. #145
    Jul 2013
    Tas
    Those wheel re-entering kits are rubbish IMO. Yes they move the pivot rearwards which is OK but they also space it down when it should be going up for lowered cars. Looks aside, I honestly don't mind the idea of the rear wheels coming forwards. It means they take on more of the car's weight and offload a small amount of weight from the front.
  6. #146
    May 2012
    ESC do a mk4 kit but the 6r rear beam mounting points are welded on not bolted.
    With the h&r 25/40 the wheel still follows the guard around with a even gap. It's the rear bumper that trails away and in that makes the gap look big at that height.
    It would be a costly exercise to try and put the back straight again. If you want to go real lows you will just have to live with it.
    Quote Originally Posted by bradsm87 View Post
    The plates are about 10-12mm thick so it lowers them F-all and there are lower points on the car. On a ruff calculation the weight spread would be under a kg rearwards. And being a short car moving them back would help stability but it would be minimal and unnoticeable.
    MY12.5 Polo 6R GTI
  7. #147
    Jul 2013
    Tas
    12mm can be noticable. Not referring to ground clearance but the angle of the trailing arm. I understand this is off topic because we're talking mk4 golfs here.
    For the Polo, I wonder if u could fit a little right angled drill up in there to drill new holes up and rearward then tack big washers on for strength.
  8. #148
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by MrDeathLad View Post
    I never actually realised it was welsed, my bad! ignore everything i have said!
  9. #149
    Nov 2010
    i'm running 8"
    8.5 is going to be too wide if you car is lowered
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
  10. #150
    Jul 2013
    Tas
    Quote Originally Posted by bigfoot View Post
    i'm running 8"
    There's a lot more factors like wherl offset and tyre size as to whether a certain combo will fit.
