is anyone running 18x8.5 et35 all round? If so how are you finding it? Thoughts?
Should be the same as the mk4 golf....
Those wheel re-entering kits are rubbish IMO. Yes they move the pivot rearwards which is OK but they also space it down when it should be going up for lowered cars. Looks aside, I honestly don't mind the idea of the rear wheels coming forwards. It means they take on more of the car's weight and offload a small amount of weight from the front.
ESC do a mk4 kit but the 6r rear beam mounting points are welded on not bolted.
With the h&r 25/40 the wheel still follows the guard around with a even gap. It's the rear bumper that trails away and in that makes the gap look big at that height.
It would be a costly exercise to try and put the back straight again. If you want to go real lows you will just have to live with it.
The plates are about 10-12mm thick so it lowers them F-all and there are lower points on the car. On a ruff calculation the weight spread would be under a kg rearwards. And being a short car moving them back would help stability but it would be minimal and unnoticeable.
12mm can be noticable. Not referring to ground clearance but the angle of the trailing arm. I understand this is off topic because we're talking mk4 golfs here.
For the Polo, I wonder if u could fit a little right angled drill up in there to drill new holes up and rearward then tack big washers on for strength.
i'm running 8"
8.5 is going to be too wide if you car is lowered
MY18 Golf 7.5R - Ecotune Stage 1
Mazda RX2 - 13B Bridgeport GTX4202R
