Page 6 of 20 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 194
Thread: Agressive wheel fitment
  1. #51
    Melbourne, Victoria
    Quote Originally Posted by Polo_GTI View Post
    Does anyone know if 18x8" +35 offset with either 225/35/R18 or 215/35/R18 tyres will fit the guards and not scrub when lowered?
    I did a test fit with a set of Momos at stock height and they had about 1-2mm poke.
    Not sure if the tyres would scrubs but is possible. But don't take my word on tyres. Isn't my strongest area with wheel fitment.
    2011 Polo GTi
  2. #52
    Nov 2010
    18x8" +35 offset with 225/35/R18
    exactly what mine is - on H&R 25/40 and yes they do rub a little if you hit a decent bump/hole but nothing i'm concerned about. i'm pretty sure it is only the front driver's side that rubs.
    i think +40 would be worse, and I wouldn't be going any lower than that at the front. If anything the back could come down another 10mm
    if you could find 18x7.5 +35 and 215/35 i think that would be ideal.
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
  3. #53
    Oct 2012
    Quote Originally Posted by bigfoot View Post
    It depends on where your getting the scrub..? i was under the impression that anyone running 8J +35 on the front was having fitment issues as it protrudes out the guard a little but there was still 5-10mm to the inner strut?
    If it's scrubbing on your fender then a +40 offset will move the wheel 5mm further in towards the strut.
    What size & profile tyres are you running on your 18x8J +35 ?
  4. #54
    Mar 2011
    Agreed...ET40 is a better offset for the 8inch rim on the front if you are lowering the car.
  5. #55
    Oct 2012
    What offset are your gram lights Atypic? Are you on lowered springs?
  6. #56
    Mar 2011
    Rays are 18x7.5 ET48 with 3 mm spacers...so ET45. Not ideal, but wheels are not flush by any stretch. I'm on H&R Monotubes with no rubbing. Changing wheels soon to eliminate any need for spacers.
  7. #57
    Mar 2011
    Carlingford
    You mean +20... +40 is a weaker offset. Should be careful about giving people advise if you don't 100% know yourself.
  8. #58
    Nov 2010
    225/35
    Quote Originally Posted by ommeh View Post
    You mean +20... +40 is a weaker offset. Should be careful about giving people advice if you don't 100% know yourself.
    no, i mean 40...there is bugger all clearance with the strut as it is. move the wheel in any closer any it may start rubbing on it. i'd rather the tyre rub on the plactic guard lining than on the strut
    but now that you mention it, 20 would be worse too
  9. #59
    Oct 2012
    225/35
    i'm guessing you don't have coilovers though? if you knew exactly where it's rubbing that'll really help me out lol
    Actually I just realised that you have H&R springs... with coilovers, you should find your self with a little more room on the inner wall
  10. #60
    Nov 2010
    yea mate H&Rs
    i might experiment with some chalk to see if i can pinpoint where it rubs
    edit:spellingz
