Enkei RPF1's: 17x8 35offset, then you can be cool like the 9n3 boys (well, 2 of us).
Assuming you have pretty close offset compatibility, should work well.
I can take 1 off for you to test-fit.
18x8 35p front and 18x9 38p in the rear![]()
Can anyone confirm what the PCD is on the Polo GTI. Ill be replacing the stock detroits very soon
5x100, just like the rest of them
Resident grumpy old fart
Damn!! That really limits my options for aftermarket lightweight jap rims :/
Welcome to our world
Although if 17" is OK, there's a fair bit of stuff made for Subarus that can fit if you're willing to run spacers.
Nah I want 18" with big offset. I was looking at time attacks but doesn't look like that's gonna happen. My old s15 had 5x114.3 and so many options. I wish it was the same for the polo![]()
I should have said 17" or larger (try looking for 5/100 in 15")
Subarus run massive offset (in the 50's) so check for 18" wheels that suit WRX's.
awesome thanks for that.
Although 50's offset is not massive, that's close to stock offset. I was looking for a low 30's offset or even 20's.
