So I ordered some really nice RS style rims from states in gloss black and gold/black trim 17x8.5j ET30 which is pretty aggressive as I had seen them fit fine on a polo only to forget that my Polo GTi has Golf GTi sized calipers on the front wheels and there is not enough back clearance to fit them which is quite upsetting.
I suspect I am going to need around 8mm-10mm additional clearance on the front to fit these. So far the plan is lowering the car as much as possible tomorrow to camber slightly and then find some 8 or 10mm hub centric/wheel centric spacers and try and get these ****ers under the guard or at least close as possible. If I have to use a 10mm spacer these wheels essentially become ET20 :| I don't even know if it's doable without bags.
Any words of advice or recommendations to get this done?
Nice nice. I just got mine slammed yesterday with H&R super lows all the way down. 40mm on front and 70mm on the rear, pretty ace.
The back is real low hahahahaha. Very close to hit but safe for now.
Jikes! Show us some pics !
Average pic but quick snap, on the stock 17's for now. See plenty of clearance I would go lower if I could
are the wheel bolts the same for GTI and TSI?
if i purchase a GTI rims like above. will i be able to fit them onto my 81TSI using same bolts ?
Volkswagen Polo 2014 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
Should be able to bro. Pretty sure all polos are m14 x 1.5, 5x100
Intense indeed
