Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 194
Thread: Agressive wheel fitment
  1. #181
    Jun 2015
    WA
    So I ordered some really nice RS style rims from states in gloss black and gold/black trim 17x8.5j ET30 which is pretty aggressive as I had seen them fit fine on a polo only to forget that my Polo GTi has Golf GTi sized calipers on the front wheels and there is not enough back clearance to fit them which is quite upsetting.
    I suspect I am going to need around 8mm-10mm additional clearance on the front to fit these. So far the plan is lowering the car as much as possible tomorrow to camber slightly and then find some 8 or 10mm hub centric/wheel centric spacers and try and get these ****ers under the guard or at least close as possible. If I have to use a 10mm spacer these wheels essentially become ET20 :| I don't even know if it's doable without bags.
    Any words of advice or recommendations to get this done?
  2. #182
    Quote Originally Posted by Swattysin View Post
    The only thing you have to worry about when dropping it a lot is cambering and the inside of the wheel hitting the strut. From what I've been told it's only about 3 degrees standard cambering without any camber adjustment purely through the motion of lowering the car. You will be fine though with those wheels, I have seen them on a bunch of polos in ET35 low as hell with no problems. I was actually going to get these wheels myself in matte black on candy white prior to finding some other wheels (which funnily enough don't fit) with a ET35 Front, ET25 rear staggered setup. Slightly risky but I have seen ET35 all around on 215's up close on @spares ride above and he plans for 10mm spacers at the back which look like it wont' have any problems. Put some pics up when they are on.
    Thank you for the info! I'll gladly post some pictures when they are fitted! This bloody winter wont pass fast enough tho!
  3. #183
    Jun 2015
    WA
    Nice nice. I just got mine slammed yesterday with H&R super lows all the way down. 40mm on front and 70mm on the rear, pretty ace.
    The back is real low hahahahaha. Very close to hit but safe for now.
  4. #184
    Jikes! Show us some pics !
  5. #185
    Jun 2015
    WA
    Average pic but quick snap, on the stock 17's for now. See plenty of clearance I would go lower if I could
    Attached Thumbnails Attached Thumbnails Agressive wheel fitment-polosmall-jpg
  6. #186
    Haha, understatement of the year
  7. #187
    May 2009
    are the wheel bolts the same for GTI and TSI?
    if i purchase a GTI rims like above. will i be able to fit them onto my 81TSI using same bolts ?
  8. #188
    Jun 2015
    WA
    Volkswagen Polo 2014 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
    Should be able to bro. Pretty sure all polos are m14 x 1.5, 5x100
  9. #189
    Jun 2015
    WA
    Quote Originally Posted by wrecksigge View Post
    I got wheels on yesterday, fronts are running at ET18 with spacers, back ET20. Need at least 3-4 degrees camber to get it to work, unsure. Intense stance. hahahah.
  10. #190
    Intense indeed
