I ran 215's on a 18x9 +38 in the rear with no issues. As low as the KW V1's would go.
I have 18x8J +35 on the rear with 225 tyres on and they scrub pretty much at every big bump or dip in the road. Even at a high stance they rub. I doubt the rear fenders are much wider than the fronts, if anything i'd say they're about the same
MY13 Polo GTI | 5 Door | Candy White | Sunroof & Bi-Xenon Factory Options
Yeah IMO 225 is way too fat for an 8 - that's why you're scrubbing. As BLN355 has pointed out you can go low on the rear with a skinny tyre and you're fine - I'm running a 195 on an 17x8" so it's a little stretch - as low as the KW V1's would go and then some with an adjuster cup and bumpstop delete and I still can't go low enough to scrub on the rear - front's a different story.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Touche
Pretty much the same parts when it comes to suspension and how much width you can fit under the arches - you guys can pull off 18's though, that I am jealous off.
OT - ATYPIC are you coming up to Albury for V-Dubs in the Square (28th April QEII Square, Dean Street Albury) - I remember ages ago you saying you have family up this way that's all.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
What size tire do you recon I should run on 17x8?
Tossing up between 205/40 or 195/45.
well considering that the rolling diameter will be different with those two, you should match that same size as standard!
Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
Plus a few other bits and pieces.
