Results 1 to 7 of 7
Thread: Additional menu's in the instrumentation cluster??? GTI
    Nov 2012
    South Africa
    Question Additional menu's in the instrumentation cluster??? GTI
    Hi Guys,
    I would like to find out, if there are any additional 'secret' menus, that can be accessed, on the 6R GTI?
    Usually it's a matter of holding down the 'down' button, press OK, etc etc, and you get into these menus......
    Without any OBD2 cables preferably....
    Can anyone help?
    Thanks
    May 2013
    sydney
    there is the climatronic menu which reads data from the CANBUS
    Climatronic hidden menu - YouTube
    VWVortex.com - Climatronic diagnostic codes
    then there is the RNS hidden menu
    RNS 510 Secret Menu - YouTube
    to access the MFD menu (I think)
    - Turned on Ignition (key half-way in, no engine running).
    - Pressed the (OK) button, the one under the wiper stalk, for 5 seconds and RELEASE.
    - Pressed the (DOWN) button at the end of the stalk for 5 seconds.
    Now the screen read:
    - MFD >
    - Setup >
    At that point you can browse and select with UP, DOWN and OK.
    The menu varies depending on options, but all options are noted in the MANUAL.
    Nov 2012
    South Africa
    Quote Originally Posted by adamolee View Post
    - MFD >
    - Setup >
    Thanks great post!
    If you do not have climatronic, then it's basically useless.....
    It's unfortunately not an option in our market... Any workarounds ?
    May 2013
    Orange NSW
    RE: Additional menu's in the instrumentation cluster??? GTI
    The best option is to buy a FIS+ module. You can have customized pages on the mfd from speed G force temps 0-100 times etc try auto-polar.com
    Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Jun 2008
    Ringwood, Victoria
    - MFD >
    - Setup >
    And none of them are available in the 6R Polo.... Not only that, but all the buttons etc for menu control and selection are on the steering wheel.
    Again, not viable or available for the Polo 6R, they do not know how to crack / will not attempt to crack into the Polo / Transporter CANBUS and diagnostics system due to it's complexity.
    So 444YYY, to answer your question, no there are not any more menus other than what is already available in the MFD settings.
    Quote Originally Posted by gavs View Post
    Quote Originally Posted by greg32 View Post
    Confirmed. Unfortunately Auto-POlar FIS+ doesn't support Polo/Transporter with integrated CANbus gateway.
    Nov 2012
    South Africa
    Thanks for the confirmation guys!
