Yes it is.
Yes it is.
I couldn't find the bluetooth module under the seat (MY12 GTI). It also doesn't have the BT dongle. Could it be behind the RCD510 / centre console?
Mod...pls move it to the BT forum. Thanks
Posting it here as unsure where else to post:
Hey guys, I just bought a 9w7 module to replace the older version (9w3?) in my MY12 Polo GTI (has manual AC controls + RCD 510). I was under the impression that it is simple swap based on what I have read and seen (images and videos).
I tried looking for the module under the driver's seat but can't find it...it has the storage compartment. Could the module be behind it? i.e. I need to remove the drawer to access it or is it behind the RCD 510? Assuming the 9w7 can fit instead of the 9w3, can someone enlighten me as to where can I find this bluetooth module?
If this requires new wiring and stuff, then I am stuffedAm a complete noob in wiring / electronics and such.
Thanks in advance.
Factory position is on the floor, not attached to the seat. Of it was aftermarket it could be under/behind the head unit.
Was the bt factory?
