The MY12.5+ Polos come with the 5K0035730F BT Module and it shows track info and changes songs fine.
And your BT model number is...
(Should be listed on your invoice/receipt email)
The RCD510 code is 5K0 035 190 (no RVC connection)
BT code is as per my posted pic on page 3 being 7P6 035 730 F
in semi related news, i reported that the address book when displaying entries is all garbled. Marc from vag-navisystems said that its a firmware fault on the RCD and that the dealer has a fix for it, but may not know anything about it, so i would need to push for it. I won't bother as i realistically never use it anyway, i just use the 6 presets, its good enough
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
Does voice recognition work on RCD510?
2011 Polo GTi
Yes, does with the BT and Rcd510 combination I refer to above. I disabled it though as I prefer the button as a mute
Cheers man, installing in on Saturday and didn't want to plug in the wrong one and have it not work. Can't be bothered pulling apart panels again :-P
2011 Polo GTi
Do you have a VCDS cable? If you want the voice recognition to work off the mic button the steering wheel you need to code it in, else it will just function as the mute button as it would do now. I prefer it to mute anyway as I found the voice recognition a hindrance more than a help anyway.
Thanks for the feedback guys.
So pontif's 7P6035730F is confirmed not to be able to skip BT tracks while readerr0r's 5K0035730F does have this feature (assuming pontif's phone supported said feature as well).
I use an iPhone4s but given it just says "BT-Audio" I suspect it may be an RCD issue not so much a BT issue, as there are people previous who have bought from bluewagen/vag-navisystems and got the proper integration so who knows. One of the ways you could work it out would be to compare the BT and RCD part number pairs. Could it be that the 'highline' RCD510 that comes with the RVC connection is a 'fuller featured' unit?
Cheers,
Aaron
