Results 1 to 7 of 7
Thread: 77tsi brake upgrade... 6r gti brakes? or new rotors
    Jul 2011
    NEWCASTLE NSW
    hey vww'ers
    i have a 2012 77tsi. at 40k the rotorss were machined due to shudder, and now at 45k they are shuddering again.
    im looking into upgrading,
    is much invoved into fitting a second hand set of 6r gti fronts? carriers etc included?
    or should i just go for a tougher aftermarket rotor and some uprated pads?
    is coding needed to go to gti fronts?
    any input is appreciated
    thanks!
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
    Quote Originally Posted by jamie88 View Post
    hey vww'ers
    thanks!
    Saving $$ for: mk6 gti
    With this in mind, get std discs and some better pads. Call GSL Rallysport tomorrow and have your VIN ready.
    Can't comment on the stress of going to GTI brakes, but there's no point in blowing hard earned when you don't need it.
    Most VWs can handle plenty of extra performance before needing bigger brakes.
    Jul 2011
    NEWCASTLE NSW
    fair call i wasnt sure how much work was involved,
    if its a pain in the a$$ i wont bother.
    Apr 2014
    Earth
    This is my mini 6 pot on my Polo 6r 1.2 tsi 77kw
    (Removed picture)
    Total overkill for a 1.2 tsi, but I think it looks mad... Lol
    Jul 2012
    Sinagra, Western Australia
    Tell whoever is putting your wheels on/off to torque the bolts correctly and you won't have shudder issues. The tiny discs on them generally warp if the hub bolts are over tightened. (eg. rattle gun at a tyre shop)
    Erskineville, NSW
    120Nm is the correct torque. preferably torque to 90 then 120 (that's my method)
    I also don't think that VW rotors take to machining very well. Generally you can only pull them down a couple of mm before you get to minimum thickness. Assuming you have the 256mm fronts then the new thickness is 22mm & min is 19mm.
    My mate has a 77tsi. He pedals it fairly hard and his main complaint about the brakes has been the dust. He fitted Remsa pads but I haven't had any feedback on what he thinks.
    mick's garage has 256mm Mintex rotors for about AUD90/pair delivered
    Oct 2010
    Melbourne, VIC
    I've been running DBA T2's in the same size as your Polo (256mm) and had them glowing red at track days without any warping (there are surface cracks on them but that's normal at that level of abuse). I got them from GSLRallySport/Brakes Direct Australia and highly recommend dealing with them.
    Resident grumpy old fart
