Page 4 of 23 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 221
Thread: 6R Polo GTI Middle Muffler Delete
  1. #31
    May 2012
    Quote Originally Posted by ATYPIC View Post
    I haven't even looked underneath this car so can someone clarify which muffler/resonator gets removed as some posters are saying front and some saying middle.
    I'm booked in at Taylor Made Exhausts in Melton...yes it's a small drive but I'm going there because this guy comes recommended by a mate who's had two cars done for $80 each.
    Let me play the guinea pig here before anyone commits as I would hate to give a recommendation only for the experience to be a failure or disappointment.
    I understand. Melton is perfect for me as in the Westeren Suburbs
    Let us know how you go.
    MY11 Polo GTi - Flash Red - Comfort Pack - Bluetooth - Tint
  2. #32
    Jun 2008
    Ringwood, Victoria
    It is the resonator/middle muffler. There is only 2 on the car so if they take out the one directly below the drivers seat, they have removed the correct on.
    Side note ATYPIC, you coming on the cruise seeing as you are in Melbourne?!?!?! we have to compare the difference between a resonator deleted exhaust and....well....something else...
  3. #33
    Mar 2011
    Quote Originally Posted by gavs View Post
    Thanks gavs that's perfect!
    Regarding the cruise...I would have definately been there but I'm off to Thailand on 23 Oct so hopefully there is another cruise before xmas.
  4. #34
    Oct 2012
    Norway
    does anyone know what size it is on the pipe and the clamps needed to replace it? is not so easy to find any retailer here in Norway which will make it ..
  5. #35
    Italy, Piemonte
    Sdrablos, the pipe diameter should be 55mm.
    Don't know if you can easily receive this from Italy, but that's the best I found here, same diameter as the original pipe: InoxCar - Volkswagen
    With the first pipe of the page, you can use the original inox-band to fix the new pipe behind the removed muffler (cutting the new pipe at the right distance).
    In the front you can cut the original pipe just where it is linear, after the double turn ahead of the muffler and fix the new pipe with the provided screw or using another band as the rear one. IMHO this is the best way to come back easily with the original muffler.
    Alternatively you can wire-weld it in the front (like I did, using a different pipe unfortunately...)
  6. #36
    Jun 2008
    Ringwood, Victoria
    Better to use a flared piece of 57mm OD pipe that sleaves over the existing front pipe. Linish the edge on the rear edge of the pipe that fits into the clamp and cool the pipe. Heat the clamp. Fit the clamp onto the pipe and then fit the flared end over the exisitng pipe and weld. Then fit th eclamped end of the pipe back onto the rear pipe of the car.
  7. #37
    Nov 2010
    anyone done this on a TSI yet?
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
  8. #38
    Oct 2012
    Norway
    got the removing don today, WOW! love the sound and the "snerr" when the next gear "pops" in also got the muffler made that I can reinstall it. Thanks for all good tips guys
  9. #39
    Cool. Did you get any photos of the parts and it in situ?
    Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
    Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
    SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
  10. #40
    Sep 2012
    Got a quote from Castle Hill Exhaust. They can do single jobs for $100. If I can get 3 or 4 Polo's done at the same time then $80 each.
    If we can agree on a day then I can book it in.
