Results 1 to 5 of 5
Thread: 6C GTI Front end clunk noises
    Nov 2018
    NSW Sydney Area
    Hi
    I have a 6C GTI and am getting loud clunk noises from front end both sides (sounds like something to do with suspension) when going over bumps but mostly when backing out of driveway with steering turned.
    Also getting faint clunk when steering full lock to the left.
    not sure if these two are related.
    Any help would be appreciated
    Apr 2015
    Loose subframe bolts maybe, I'd start by checking them first.
    Gary
    Nov 2018
    NSW Sydney Area
    ok thanks m8
    where would i locate them?
    Apr 2015
    Quote Originally Posted by kentwbird View Post
    ok thanks m8
    They bolt the subframe to the chassis, vertically. So it's an under the car job, with a tension wrench, sockets and a long extension to get to the bolts that go through the subframe. The subframe location is mildly adjustable which mostly affects the camber, side to side. So a wheel alignment afterwards to make sure that it is the best position, so the camber is even side to side.
    Gary
    Front pads moving around in calipers when moving backwards. Normal
    MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
    T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
