Usually you dont need to remove it if you have a body tool or even a wider screwdriver you can ease the cable between the windscreen and the trim.
I have never removed the trim in 6 installs. If you hard wire it do it properly and dont jamb wires down the sides of fuses
Use these for safety and one of these so you can use the original plug as some run on 5 V.
If you dont know how to use these best get someone who does.
