loj94jdn: Some very good questions indeed. First thing to appreciate is that 12V car fuses really aren't intended as overload protection devices - they are much better at fault protection (which is an entirely different thing)! Also, whilst the written number on the body of a fuse is important, it's a nominal rating only.
The old rule-of-thumb used to be that it is unwise to operate a circuit with a fuse of a certain rating if the current flow was above 75% of that rating.
Just because a fuse has the number "20" (say) doesn't mean that the fuse will blow @20 Amps. What happens is that the current-sensitive material in the fuse starts to melt at a much lower current - so it really depends on the time characteristics of the overload/fault as to what actual current the fuse element opens the downstream circuit. For example - it would not be unusual for a 20 Amp fuse to open @ 40 Amps - if the profile of the fault was characteristic.
If your ice-box has a 4.5 Amp compressor- then it will draw 63 Watts @ a nominal 14 Volt (which will likely be the general rail voltage with the engine running) - when chilling. A circuit with a 20 Amp fuse should easily be able to manage this load.
