Ahhh ok. My Polo does not have this in the fog light part so that's where I was getting confused.
Sorry buddy I can't help ya then. However if the connection is similar to the one posted above then I can't see why It wouldn't work?
I think you inadventantly answered your own question. The 6R has 2 fundamental systems with many varients of them but we will just narrow it to 2 for arguments sake. There is GTi canbus and regular 6R canbus, the 6R is much more integrated whereas the regular 6R system is not. If you are not getting bulb-light errors on the dash, this does not mean that the light isn't throwing an error. I would start by getting your hands on some properley specced LED bulbs from somewhere like hids4u.co.uk and see if these work for you.
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
Thanks, good idea. I had no idea that the same bulb shape/style could go by so many different names! Any idea what I should be looking for at hids4u.co.uk? I can see bulbs listed on their site by the names of 380, 382, 581 and 241, all of which look potentially suitable.
Hi scobb,
time ago I solve same problem. It is nothing CAN compatible and nothing else.
Only thing is you have (not only you but everybody) changed polarity in your bulb base in
day lights.
There are 2 ways how to connect it:
1. Go to VW dealer and they change pins in base bulb connector, now you have - on a middle
and + on metal part of the bulb. because of plastic base nothing happen.
2. you have to disolder and open bulb you received from ebay and install there SMD rectifier
and after doesn't matter how you connect your bulb to polarity.
After you make one from these changes bulb will lit normally!!!!!
I found same strange polarity at my friend's Skoda Octavia II FL MY2010, I chosen 2nd possibility
and everything worked properly.
My friend with Skoda chosen 1st possibility and everything worked properly as well![]()
http://www.audi-sport.net/vb/forumdi...?209-em-tuning
Speak to t8ups,
Builds custom led replacements with Inbuilt resistors. Vags have issues with the inbuilt sensors which can cause a lot of issues
O and cheap to!
Guys,
it is not so problem with CAN compatibility but only with reversed polarity in bulb base...
Explanation: before I had Golf V and recognized there was different wrong bulb identification - in case I changed LED bulb instead of
original one, switch on an ignition - control unit made measurement and disconnect voltage from this bulb. Voltage been restored
after each switch - on ignition...
I measured it in new Polo and Skoda is different system - control unit test bulbs by different way - it try to adapt
on lower currents through LED and didn't switch off voltage from bulb.
I changed LED for daylight lights, sign lights ... and everything working properly without any indication and I used bulbs without
any built in resistor
