Originally Posted by
Bassik
Was it difficult taking the fog lights out. I have yet attempt this?
It's pretty straightforward:
1. If you look at the black plastic surround that surrounds the fog light, you will see a small hole in the plastic beneath the light. I just hooked a piece of bent stiff wire through the hole and pulled with moderate force. There are a couple of plastic lugs that hold it in position, but they come away nicely and quite easily when you pull the panel this way.
2. Once the plastic surround has been removed, you'll need a torx screwdriver to remove 2 screws holding the light in place at the bottom.
3. With the screws removed, lever upwards the 2 lugs that hold the light in place at the top and the light assembly will pop out.
