I noted the 1.2 81kw Cross Polo here has larger front brakes than the 1.2 66kW Polo and smaller than the GTI.
Hey guys,
I've looked around google and haven't been able to find a solid set of numbers for the sizes of the brakes on the 1.2tsi. DBA has a few options for both front and rear, so I'm not 100 percent certain.
Could anyone tell me diameter the front and rear disks are on the 1.2tsi polo. I'm after some DBA T2 rotors for the car, and bendix pads.
I'm led believe it's 256mm front and 232mm rear.
What year model is it? What kw motor does it have?
Based of this:
Engine PR No. Rear brakes 1.2l - 66 kW 1KT / 2EJ C 38 (14”) 1.4l - 66 kW TDI 1.4l - 77 kW TDI 1.2l - 81 kW 1.4l - 110 kW 1.8l - 141 kW 1KV
Engine PR No. Front brakes 1.2l - 44 kW 1LR / 1ZG FS III (14”) 1.2l - 51 kW 1.2l - 66 kW 1.2l - 77 kW TSI 1) 1.4l - 63 kW 1.2 l; 1.6 l - 55 kW TDI 1.6l - 66 kW TDI 1.6l - 77 kW TDI 1ZC FN3 (15”) 1.2l - 77 kW TSI 2) 1.4 l - 103 kW TSI
1) Worldwide and Europe up to Week 22/2012
2) Europe as of Week 22/2012
I think this is what you need (i think this is still the same for the 1.2L 77kw motor also):
Item PR No. 1LR / 1ZG / 1ZJ 1 Brake caliper FS III (14”) 2 Brake pad,
thicknessmm 14 Brake pad, wear
limit without
backplatemm 2 3 Brake disc Diam‐
eter in
mm256 Brake disc,
thicknessmm 22 Brake disc,
wear limitmm 19 4 Brake caliper,
pistonDiam‐
eter in
mm54
Rear brakes (disc brakes)
Item PR No. 1KT / 2EJ /
1KV1 Brake caliper C 38 (14”) 2 Brake pad,
thicknessmm 12 Brake pad,
wear limit with‐
out backplatemm 2 3 Brake disc Diameter in
mm230 Thickness mm 9 Wear limit mm 7 4 Piston Diameter in
mm38
Mitch, it's a 2010 77tsi. I had a look at the service manual and think what you've got above is right, 256 front, 230 rear
Front brakes are 256mm and the rears are 232mm
