![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
gavs
An easier solution if you are after effective chilling is to buy one of
these and fit it to an air-to-air intercooler.
I'd rather go the water/methanol injection route than IC cooling or air/water IC since you get the more complete combustion as well as the charge cooling benefit.
Resident grumpy old fart
