Results 1 to 10 of 21
Thread: Wipers
    May 2007
    West Ryde, NSW
    Paid $24 for a pair of front wiper refills (this is simply the rubber strip that you cut to size) and $21 for the rear wiper (this includes the clip as apparently you cannot use the refill) from VW.
    All up $45, which is lower than super cheap which wanted $58 just for the front wipers (although I think this includes the clip and is already cut to size for you).
    Thanks for the help guys.
    NickZ
    Former ride: MY07 Black Polo GTI
    Current: MY09 Blue Passat R36 Wagon
    Jun 2009
    Malaysia
    I would suggest a DIY for the wiper blades. Then you can buy those silicon refills and slide it into the original banana wipers that's OEM on the PoloGTI.
    i've used the picturial guide below on my polo
    picturial guide - http://forums.vwvortex.com/zerothread?id=1818550
    Maybe the text guide will help some as well.
    text guide - http://forums.vwvortex.com/zerothread?id=2603696
    use the PIAA wiper blade refills, they are the industry leader for silicone wipers...the most expensive, but quality stuff
    have fun
    iggie
    Got mine (front wipers) for $25 thru VW and its the whole set, not just the refills.
    Jan 2009
    wipers
    Hi all
    With the rear wiper you can pull it apart and just replace the rubber (silcone) part.
    It does not look like it comes apart but it does and the rubber bit is the same as any other wiper.
    I cannot speak for the front wiper blades but I imagine that they are the same
    Dec 2008
    South Africa
    from VW you get the complete unit with blades thats why they are so expensive..
    i replaced all my blades front and back ( was covered under my automotion maintainance plan btw it also covers cltuch for wear and tear i might just give it a try to replace my clutch next year before my plan expires ) my current clutch has 25 000 KM on its a new one as the previous one was covered under warranty.. oil somehow leaked into it...
    Jun 2007
    Newcastle, NSW
    Hi All,
    I have replaced my two front wipers easily thanks to this guide http://www.vwwatercooled.org.au/newf...ad.php?t=10687 and am also wanting to replace the rear wiper blade.
    I had a quick look at it and it appears to have some tabs on each end that can be removed. Before I start attacking it, is this an easy swap and are there and tricks to follow?
    Cheers,
    cliffo
    May 2009
    O_o
    I just paid some outrageous amount for VW to do it for me ($110)
    06 > 9N Polo GTi
