Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: wiper activation + washer
    Jul 2005
    Quote Originally Posted by jesum View Post
    is there some way to retain fluid in the tubes that feed the nozzles?
    you will probably find its to do with the type of pump that is used. it allows the water to gravity feed back through it over time and back into the reservoir.. so the delay you are seeing is the priming of the pump and the water filling up the tubes.
    if you use the washers then wait a few minutes and use them again you may not see the delay as the pump is already primed from the previous use and the tubes may still be almost full of water from the previous use. a simple solution could be to fit a small check valve into the tubing so that it stops the backflow of water.
    just a thought.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Sep 2010
    Scotland
    Like this?
    Link
    its translated from a german site but he seems to add a valve of some sort maybe to fix this problem?
    Its kind of hard to make out because its translated
    Jul 2005
    yes... like that. just make sure you use the right type of check valve. you need one that is not very restrictive in its forward flow mode so that you still get a nice strong squirt onto the windscreen.
    Jun 2009
    PJ/Selangor, Malaysia
    how did you find that, MGrove03? nice find! time to study it a bit more.
    Jun 2009
    hmmmmmmmm after looking at it for a while, i have 2 comments:
    1. i should be able to get any plain check valve for this as long as the valve fits into the hoses
    2. why did he delete the first valve under the wiper? that seems unnecessary as long as there is a check valve right next to the water pump.
    3. having a check valve at the position of the first valve (to avoid having to remove the bumper also) might not work very well since you may introduce an air pocket between the first valve and the water tank. in this setup, activating the stalk may get you a short squirt of water (from the water stored between the check valve and the washer) and then nothing for a while (from the airpocket between the check valve and the water tank) and then water again (when the water from the water tank finally makes it up to the top).
    thoughts, folks??
    Sep 2010
    Scotland
    just a random site i came across ages ago. Decided to bookmark it in case any of the guides came in useful and it looks like one of them did lol
