Results 11 to 20 of 24
Thread: Will this stop surge?
    Jan 2009
    sunshine coast
    not trying to post to off topic either. but not to sound like a complete spanner, but what exactly does the r1 diverter do that the stock diverter doesnt? is it just build quality?
    Sep 2006
    Brisvegas
    TBH Mozzy I have never felt this surging that is mentioned, with a forge dv. It was more of a way to get a little extra power out of the car at the top end but after going phase 2 I don't think I need it. but I thought the valve could help.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Feb 2008
    I have never had any of this surging either...I have refitted my Forge Splitter valve, ans adjusted it properly(since I found that I was the problem, not the valve). I have been told that the stock DV is only good for 9PSI of boost. I don't know how true this is, but testing between the stock, Forge, and another brand DV, I have found that the stock one was bleeding off the boost at about 5000RPM.
    Mar 2007
    Quote Originally Posted by Blitzen View Post
    Spot on, Ryan. Had the same experience and put in the same DV.
    Dave
    Quote Originally Posted by mikepologti View Post
    Any replacement DV not just an R1 would be an improvement on the standard plastic one. Better able to handle increased boost.
    Most are a piston but the R1 may be a diaphragm I can't remember.
    Jan 2009
    WEst Sydney
    I have the APR Diverter valve and it doesnt stop the surge..
    its the wastegate.. The N75 bleeds to early on.. gotta stop the flow to it..
    hence my little contraption... It cant be bad thing as if worst comes to worst, ill leave it completely open as it would be stock..
    Alfred Cove, WA
    Quote Originally Posted by shaneth View Post
    I don't see how a valve that is made to do this is dodgy.
    Its dodgy because you might find a good setting on day 1.... day 15 comes along and it has vibrated to a different position and has a leak up the valve stem. Ball valves can also be blown open if you dump enough flow into them, hence will alter your setting.
    Quote Originally Posted by Kai View Post
    And then dont forget the most important mod for gays.
    Blow off valve - 300
    Sep 2006
    Brisvegas
    Quote Originally Posted by Ben_GTI View Post
    Ok if you think so. Im sure plenty of Jap cars out there would disagree with you. As this was recommended to me by a car tuner for how good they are, hey what would he know. It must be dodgy.
    Boost controller must really be crap if they can hold 15psi.
    Have a Look
    CUSTOM CODE
    Phase 2
    Jan 2009
    sunshine coast
    i think from memory the forge one was piston based as well , but better build quality.and im pretty sure your right about the r1 dv, i think its diaphram based.
    thanks for the info, you just talked me into a r1 in the near future.
    Alfred Cove, WA
    Yes I do think so I have a general rule of thumb, if I can buy it at Bunnings, it doesn't go near my GTI. My Mk3 is a different issue hehehe.
    Mate, not sure what you mean about a boost controller. They are designed for this, I'm talking about something you get from Bunnings as per the original post. I totally agree a boost controller which has an actuator attached to a valve will hold the ball or gate in a desired position, if you have a free handle, its free to do whatever it wants. Do you really want to be driving along and have the valve vibrate open of its own accord?
