Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Will this stop surge?
    Jan 2009
    WEst Sydney
    Hi,
    We all know about our roller coaster dyno results. This has been shown to be due to wastegate opening/shutting etc etc...
    I have seen a thread which talks about restricting flow to the N75. Will this device do the trick?
    So if this tap is partially closed will the N75 not have the issue of opening the wastegate erratically due to getting air at the wrong times etc..... delay the effect of opening the wastegate..
    My question is as follows
    1. how much would you restrict the air to the N75? fully, half etc etc
    2. Is flow and pressure a different thing? does this contraption make it unsafe?
    Jan 2009
    WEst Sydney
    Another photo... the valve is almost shut..
    Sep 2006
    Brisvegas
    I think you would probably want a gated boost controller. This blocks the flow of air to the wastegate until a certain psi that you have set. I was thinking of doing this but have decided not to do it. I have one if your interested, pm me.
    As to which line you want it on or if it will give you the disired affect I'm not sure as I didn't get that far with my reaserch.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Aug 2008
    Quote Originally Posted by shaneth View Post
    I remember reading somewhere that boost controllers will not work on the Polo's as the boost is controlled by the ECU. Is this true?
    Cheers,
    John
    Sep 2006
    Brisvegas
    Quote Originally Posted by JCM308 View Post
    Yes you are right. But I wasn't going to use it as a boost controller. Just a way of stopping boost getting to the wastegate so it doesn't bleed early.
    Have a Look
    CUSTOM CODE
    Phase 2
    Aug 2008
    So does this mean the boost level wouldn't increase but boost would stay consistant to redline?
    Cheers,
    John
    Sep 2006
    Brisvegas
    Well that's the theory behind it. As I said I haven't tried it.
    Have a Look
    CUSTOM CODE
    Phase 2
    Alfred Cove, WA
    Just change the internal diameter of the line plumbed back to the TIP. A valve seems dodgy as, balls loosen up over time, or seize up depending on their construction.
    Get a solid 50mm length of stainless which you can fit your hose to. Then get the centre bored out, so do some calculations work out your desired flow rate % change and have that size hole bored out. A knife and 2 hose clamps later bob's your uncle.
    Quote Originally Posted by Kai View Post
    And then dont forget the most important mod for gays.
    Blow off valve - 300
    Sep 2006
    Brisvegas
    I don't see how a valve that is made to do this is dodgy.
    Have a Look
    CUSTOM CODE
    Phase 2
    Nov 2008
    Wembley, WA
    I hope this aint to far off the thread but since I installed the APR R1 diverter valve I have not experienced any surge since it last happened prior to that install. Must say the performance of the R1 is incredible to say the least.
