It really does look a LOT like the one vwthunder fitted
http://www.vwwatercooled.org.au/foru...tml#post828487
Keep us (or at least me!) informed if you get this.
I found this intercooler.
Seat Ibiza Intercooler TDI/1.8T MK4 - THSINT-IBZ
It seems to be the same one that people have installed on the 9n3 but with a slightly thicker core.
Similar to the forge seat sport model as well.
Can anyone confirm whether this will fit the Polo. Seems to be a good price.
Cheers.
Resident grumpy old fart
Seeing as the Forge intercooler looses pressure, i would be worried about using anothe of their products
MODS- TOO MANY
This isn't the forge intercooler model that loses pressure.
The link above is for the seat intercooler, not a forge GTI intercooler.
The link below is for the forge intercooler for the Polo GTI that loses pressure.
Forge Motorsport | Alloy Fabrication
There is a large difference between the two intercoolers.
Forge also make a version for the seat intercooler:
FMINTSSIBP - Forge Motorsport Sports Style Intercooler - Seat Ibiza MK4 1.8T | eBay
Massive price difference.
The seat design is the prefered choice with almost no pressure drop from the research that I've done.
Plus apparently a clean install. Less cutting than the Forge GTI version.
Not forge!
Good, cheap.
Forge GTI
Crap
Forge Seat sport
Good, expensive.
Again this is what I have dug up from reading the forums.
The top link is a seat intercooler with a thicker core.
So it's similar in design to the Seat Sports IC, not the same. It could be better, how can you tell.
Given that i am still looking for a good intercooler, this thread is great.
Keen on understanding the differance between the seat and ths seat cooler.
Besides a larger core, anyone seen any stats on pressure / temp comparisons?
Thanks
Clint
Polo 9n3 GTI
The unit that I am looking at is totally different to the forge GTI intercooler.
The forge GTI intercooler is a bad design apparently.
The seat apparently flows well and is good for standard to hi HP applications.
The Seat intercooler happens to fit the GTI.
From what I learnt when I was looking at the SEAT Intercooler - THS took the design and made it better, so in theory this is the BEST intercooler you can buy for the GTI. You will need Forge, SEAT or custom piping (like what Troy did).
These pop up from time to time on Ebay UK for pretty cheap. And it will fit without any modifications to the front bar. Any engine, transmission or suspension (etc) parts from the 6L Ibiza FR (not cupra) will fit the Polo.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
OOPS
Didnt check the link, thought people were talking about the Forge item for the Seat.
Yes it looks like a Seat Sport copy
MODS- TOO MANY
